Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Display Faulted System Components (Web)
Display the Gateway Status LEDs States (Web)
Display the Aggregate Sensors State (Web)
Display Power Supply Status (Web)
Display Board-Level Voltages (Web)
Display Internal Temperatures (Web)
Display the Oracle ILOM Sessions (Web)
Display the Oracle ILOM Event Log (Web)
Checking the Status of Services (Web)
Display the HTTP Service Status (Web)
Display the HTTPS Service Status (Web)
Display the SSL Certificates (Web)
Display the SNMP Service Status (Web)
Display the SNMP Service User Accounts (Web)
Display the SNMP Service Communities (Web)
Display the IPMI Service Status (Web)
Display the DNS Client Status (Web)
Display the SMTP Client Status (Web)
Display the Network Time Protocol Servers (Web)
Verifying Other Aspects With Oracle ILOM (Web)
Display the Alert Properties (Web)
Display the Oracle ILOM User Accounts (Web)
Display the Remote Log Hosts (Web)
Display the Network Management Configuration (Web)
Display the CLI Session Timeout (Web)
Display System Component FRU ID (Web)
Display the Firmware Version (Web)
Display the Oracle ILOM Version (Web)
Display System Identification Properties (Web)
Performing General Tasks on Oracle ILOM Targets (Web)
Restart the Management Controller (Web)
Clear Faulted System Components (Web)
Clear the Oracle ILOM Event Log (Web)
Set the Remote Log Hosts (Web)
Configure the DNS Client (Web)
Configure the SMTP Client (Web)
Back Up the Configuration (Web)
Restore the Configuration (Web)
Create a Snapshot of the Gateway State (Web)
Snapshot Dataset Information (Web)
Set the Network Management Parameters (Web)
Set the System Identification Properties (Web)
Performing Oracle ILOM User Tasks (Web)
Add an Oracle ILOM User Account (Web)
Change an Oracle ILOM User's Password and or Role (Web)
Delete an Oracle ILOM User Account (Web)
Disable the HTTP Service (Web)
Enable the HTTPS Service (Web)
Install a Custom SSL Certificate and Key (Web)
Remove the Custom SSL Certificate and Key (Web)
Disable the HTTPS Service (Web)
Configure the SNMP Service (Web)
Add SNMP Service User Accounts (Web)
Modify SNMP Service User Accounts (Web)
Delete SNMP Service User Accounts (Web)
Add SNMP Service Communities (Web)
Modify SNMP Service Communities (Web)
Delete SNMP Service Communities (Web)
Download SNMP Service MIBs (Web)
Disable the SNMP Service (Web)
Disable the IPMI Service (Web)
Managing Other Aspects With Oracle ILOM (Web)
Enable Alerts to Send SNMP Traps (Web)
Enable Alerts to Send PETs (Web)
Enable Alerts to Send Email Alerts (Web)
Set the CLI Session Timeout (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Note - If you are going to downgrade the firmware to a version earlier than 2.1, you must disable secret M_Keys. Refer to Gateway Administration, disabling secret M_Key functionality.
Note - If you are going to downgrade the firmware to a version earlier than 2.0, you must remove user partitions and depopulate the Subnet Manager nodes list. Refer to Gateway Administration, removing partitions for firmware downgrade.
% ssh -l root gateway_name root@gateway_name's password: password #
where gateway_name is the host name of the management controller. Initially, the password is changeme.
# disablesm Stopping partitiond daemon. [ OK ] Stopping IB Subnet Manager.. [ OK ] #
# df -h /tmp Filesystem Size Used Avail Use% Mounted on tmpfs 250M 240K 249M 1% /tmp #
In this example, there are 249 MB available. If not enough space is available, you must delete files from the /tmp directory.
# df -h /config Filesystem Size Used Avail Use% Mounted on /dev/hda2 16M 3.6M 11M 25% /config #
In this example, there are 11 MB available. If not enough space is available, you must delete files from the /config directory.
# df -h /var/log Filesystem Size Used Avail Use% Mounted on /dev/hda3 16M 3.6M 11M 25% /var/log #
In this example, there are 11 MB available. If not enough space is available, you must delete files from the /var/log directory.
# free -m total used free shared buffers cached Mem: 498 104 393 0 12 47 -/+ buffers/cache: 45 453 Swap: 0 0 0 #
In the -/+ buffers/cache: row of the free column, there should be at least 150 MB free memory. In this example, there are 453 MB available. If not enough memory is available, you must exit nonessential applications that are running.
The Firmware Upgrade pane is displayed.
A dialog box opens and asks you to confirm.
The Firmware Upgrade window changes to Upgrade mode and now accepts a URL and file name of the gateway firmware package.
Note - For the specified URL, the FTP, HTTP, and TFTP protocols are supported.
Oracle ILOM transfers the gateway firmware package to the management controller. Oracle ILOM verifies the package integrity and displays the current versions of the firmware and versions in the package.
The upgrade begins and the status of the upgrade is reported.
When the upgrade process ends, a log and summary report are displayed.
A final status is displayed, the upgrade either:
Succeeded
Partially succeeded
Failed
Refer to Gateway Administration, restarting the entire gateway.
Note - The restart process takes between 4 to 5 minutes to complete.
You can monitor the update progress through:
web browser – http://gateway_name
CLI – telnet gateway_name 1234
where gateway_name is the host name or IP address of the management controller.
Note - The Oracle ILOM stack requires at least 2 minutes to become operational after a reboot.
% ssh -l ilom-admin gateway_name ilom-admin@gateway_name's password: password -> show /SYS/Fabric_Mgmt NOTE: show on Fabric_Mgmt will launch a restricted Linux shell. User can execute switch diagnosis, SM Configuration and IB monitoring commands in the shell. To view the list of commands, use "help" at rsh prompt. Use exit command at rsh prompt to revert back to ILOM shell. FabMan@gateway_name->enablesm Starting IB Subnet Manager. [ OK ] Starting partitiond daemon. [ OK ] FabMan@gateway_name->
