Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays the Subnet Manager log.
showsmlog [-h]
This hardware command first displays the parameters of the Subnet Manager configuration file, and then the chronological log entries for the Subnet Manager within the management controller. Tapping the space bar displays the next screen of the log. Pressing the Q key quits. The -h option provides help.
The showsmlog command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the Subnet Manager log with the showsmlog command.
Note - The output of the example is a very small portion and will differ from your output.
FabMan@gateway_name->showsmlog Jul 31 15:27:56 061000 [B7D328D0] 0x03 -> OpenSM 3.2.6_20120730 - Oracle patch 11.3 ------------------------------------------------- OpenSM 3.2.6_20120730 - Oracle patch 11.3 Reading Cached Option File: /etc/opensm/opensm.conf Loading Cached Option: sm_sl = 1 Loading Cached Option: packet_life_time = 15 . . . Sep 05 04:49:30 976000 [B765AB90] 0x02 -> osm_report_notice: Reporting Informational Notice "CapabilityMask, NodeDescription, Link [Width|Speed] Enabled changed" from LID 1, GUID 0x00212856d102c0a0, new CapabilityMask 0x4250084a Sep 05 04:49:30 993000 [B6658B90] 0x02 -> Fabric has 1 switches - topology is not fat-tree. Falling back to default routing Sep 05 04:49:30 993000 [B6658B90] 0x01 -> ucast_mgr_route: ftree: cannot build lid matrices. (END) FabMan@gateway_name->
