Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspect the Data Cable Hardware
Inspect the Data Cable Connectors or Transceivers
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
This procedure describes how to remove the cables from the gateway chassis, so that the cable can be replaced. If you are removing all cables for gateway replacement, start removing the cables from the left side of the gateway, working your way to the right.
Note - These instructions are valid for both InfiniBand and Ethernet data cables.
The cable connector comes free.
The MTP connector and fiber optic cable come free of the transceiver.
The transceiver comes free.
![]() | Caution - Do not allow the cable or transceiver to drop or strike the floor. Jerking, bending, pulling on, or dropping the cable can damage the cable. |
See Install a Data Cable.
