Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Queries InfiniBand switch forwarding tables.
ibroute [-d][-a][-n][-D][-e][-G][-h][-M][-s smlid][-v][-V][-C ca_name][-P ca_port][-t timeout][lid|dr_path|guid [startlid [endlid]]]
where:
smlid is the Subnet Manager LID.
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
lid is the local identifier.
dr_path is the directed path.
guid is the global unique identifier.
startlid is the starting local identifier.
endlid is the ending local identifier.
This InfiniBand command uses SMPs to display the forwarding tables for the specified switch LID and optionally, the LID range. By default, the range is all valid entries from 1 to FDBTop.
The ibroute command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the ibroute command and their purposes.
This example shows how to display the forwarding table for LID 15 with the ibroute command.
Note - The output for your InfiniBand fabric will differ from that in the example.
FabMan@gateway_name->ibroute 15 Unicast lids [0x0-0xf] of switch Lid 15 guid 0x0021283a8389a0a0 (Sun DCS 36 QDR switch localhost): Lid Out Destination Port Info 0x000e 023 : (Channel Adapter portguid 0x0003ba000100e38a: 'mnm33-43 HCA-1') 0x000f 000 : (Switch portguid 0x0021283a8389a0a0: 'Sun DCS 36 QDR switch localhost') 2 valid lids dumped FabMan@gateway_name->
ibroute man page
