Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays size of topology.
checktopomax [-h][-l][-v]
This hardware command is a script that verifies if the number of switches and HCAs found in the InfiniBand fabric is less than the maximum values of 48 switch chips and 1500 CAs.
The checktopomax command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This table describes the options to the checktopomax command and their purposes.
This example shows how to verify the number of switches and HCAs within your InfiniBand fabric with the checktopomax command.
Note - The output for your InfiniBand fabric will differ from that in the example.
FabMan@gateway_name->checktopomax -v checktopomax: INFO: You have allowed max number of Switch elements to be 48 checktopomax: INFO: You have allowed max number of CA elements to be 1500 checktopomax: INFO: Number of Switch elements empiric found by application /usr/sbin/ibnodes: 2 checktopomax: INFO: Number of Ca elements empiric found by application /usr/sbin/ibnodes: 7 FabMan@gateway_name->
