| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Enables a gateway port.
enablegwport connector [-discoverpkey p_key]
where:
connector is the name of the connector hosting the port (0A-ETH-1 to 0A-ETH-4, 0A-ETH, 1A-ETH-1 to 1A-ETH-4, and 1A-ETH).
p_key is the partition key (1 to 7fff or default).
This hardware command enables a previously disabled connector and its associated port on the gateway. The -discoverpkey option specifies a discovery P_Key, other than default, used by the BridgeX manager.
The enablegwport command is available from the /SYS/Gateway_Mgmt and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to enable the gateway port at connector 0A-ETH-3 with the enablegwport command.
FabMan@gateway_name->enablegwport 0A-ETH-3 FabMan@gateway_name->
