Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays host nodes.
ibhosts [-h][topology|-C ca_name][-P ca_port][-t timeout]
where:
topology is the topology file.
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
This InfiniBand command is a script that discovers the InfiniBand fabric topology or uses the existing topology file to extract the channel adapter nodes.
The ibhosts command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the ibhosts command and their purposes.
This example shows how to display the host node GUIDs with the ibhosts command.
Note - The output in the example is a portion of the full output and varies for each InfiniBand topology.
FabMan@gateway_name->ibhosts Ca : 0x00212856cd22c000 ports 2 "SUN IB QDR GW switch mnm34-97 Bridge 0" Ca : 0x00212856cd22c040 ports 2 "SUN IB QDR GW switch mnm34-97 Bridge 1" Ca : 0x0002c903000891aa ports 2 "mnm34-54 HCA-1" Ca : 0x00212800013ece9e ports 2 "mnm34-55 HCA-1" Ca : 0x0003ba000100e370 ports 2 "mnm34-60 HCA-1" . . . FabMan@gateway_name->
ibhosts man page
