| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Tests Subnet Manager configuration.
smconfigtest [spine|leaf][-l][-h]
This hardware command tests the Subnet Manager configuration and reports if it is corrupt.
The smconfigtest command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This table describes the options to the smconfigtest command and their purposes.
This example shows how to test the Subnet Manager configuration (priority is 6) with the smconfigtest command.
FabMan@gateway_name->smconfigtest leaf smconfigtest:ERROR: /etc/opensm/opensm.conf file has illegal sm_priority : 6 , please change to 5 SubnetManager configuration is invalid for leaf switch. FabMan@gateway_name->
