| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Enables a connector or switch chip port.
enableswitchport [--automatic|--reason=reason] connector|ibdev port
where:
reason is the reason for disabling the port, Blacklist or Partition.
connector is the number of the QSFP connector (0A to 15B).
ibdev is the InfiniBand device name (Switch, Bridge-0-0, Bridge-0-1, Bridge-1-0, Bridge-1-1)
port is the number of the port (1 to 36).
This hardware command enables a QSFP connector and port on the switch chip or a port on the BridgeX chips. The command addresses either the connector or the port on the switch chip or the BridgeX port.
The --reason option enables you to use the Blacklist or Partition passphrases to unlock the state of the port as locked using the disableswitchport command.
The enableswitchport command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This table describes the options to the enableswitchport command and their purposes.
This example shows how to enable and de-blacklist connector 14A with the enableswitchport command.
FabMan@gateway_name->enableswitchport --reason=Blacklist 14A Enable Switch port 7 Initial PortInfo: # Port info: DR path slid 65535; dlid 65535; 0 port 7 LinkState:.......................Down PhysLinkState:...................Disabled LinkWidthSupported:..............1X or 4X LinkWidthEnabled:................1X or 4X LinkWidthActive:.................4X LinkSpeedSupported:..............2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkSpeedEnabled:................2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkSpeedActive:.................2.5 Gbps After PortInfo set: # Port info: DR path slid 65535; dlid 65535; 0 port 7 LinkState:.......................Down PhysLinkState:...................Polling FabMan@gateway_name->
