| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Sets the Subnet Manager priority.
setsmpriority priority|list
where priority is a number from 0 (lowest) to 13 (highest).
This hardware command sets the priority of the Subnet Manager within the management controller. You use this command when there are multiple Subnet Managers in the InfiniBand fabric. By setting a Subnet Manager to a higher priority than the other Subnet Managers, it becomes the or master Subnet Manager. When you set a Subnet Manager to a priority lower than the master Subnet Manager, it becomes a standby Subnet Manager. The list option provides a listing of the Subnet Manager settings in respect to priority, controlled handover, and subnet prefix.
The setsmpriority command writes the value of priority to the sm_priority parameter of the configuration file.
Note - You must stop or disable the Subnet Manager before using the setsmpriority command. See disablesm Command.
Note - Setting Subnet Managers of the same fabric to the same priority can have undesirable results.
The setsmpriority command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to set the priority of the Subnet Manager to 5 using the setsmpriority command.
FabMan@gateway_name->setsmpriority 5 Current SM settings: smpriority 5 controlled_handover FALSE subnet_prefix 0xfe80000000000000 M_Key 0xabbababe0001 Routing engine FatTree FabMan@gateway_name->
This example shows how to display the current settings of the Subnet Manager priority, controlled handover, subnet prefix, M_Key value, and routing algorithm with the list argument of the setsmpriority command.
FabMan@gateway_name->setsmpriority list smpriority 0 controlled_handover FALSE subnet_prefix 0xfe80000000000000 M_Key 0xabbababe0001 Routing engine FatTree FabMan@gateway_name->
