Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Deletes a connector from a LAG.
dellagport lagname connector1 [connector2 [...connectorN]]
where:
lagname is the identifier of the LAG
connector1 is the name of the first connector to be removed from the LAG (0A-ETH-1 to 0A-ETH-4 and 1A-ETH-1 to 1A-ETH-4).
connectorN is the name of the last connector to be removed from the LAG (0A-ETH-1 to 0A-ETH-4 and 1A-ETH-1 to 1A-ETH-4).
This hardware command removes an external gateway Ethernet port from an existing LAG.
The dellagport command is available from the /SYS/Gateway_Mgmt and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to remove connector 0A-ETH-3 from the LAG named test with the dellagport command.
Note - The output for your InfiniBand fabric will differ from that in the example.
FabMan@gateway_name->dellagport test 0A-ETH-3 Lag updated FabMan@gateway_name->
