| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Inspect the Power Supply Hardware
Inspect the Power Supply Connectors
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
You must determine which power supply is faulty before you replace it.
See Check Power Supply Status LEDs.
If a power supply is faulty, replace it. See Remove a Power Supply.
-> show -d targets /SP/faultmgmt
If a power supply is faulty, you will see /SYS/PSUx listed in the output under Target:, where x is 0 (left power supply) or 1 (right power supply).
For example:
/SP/faultmgmt
Targets:
0 (/SYS/PSU0)
->If a power supply is faulty, replace it. See Remove a Power Supply.
If a FRU value in addition to or different from /SYS/PSUx is displayed, see Clearable Fault Targets to identify which component is faulty.
In no Oracle ILOM targets are listed, go to Step 5.
