| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Remove the Gateway From the Rack
You must determine if the battery is faulty before you replace it.
-> show -d targets /SP/faultmgmt
If the battery is faulty, you will see /SYS/MB listed in the output under Target:.
For example:
/SP/faultmgmt
Targets:
0 (/SYS/MB)
->-> show -d properties /SP/faultmgmt/number/faults/0
where number is the number to the left of /SYS/MB. For example:
-> show -d properties /SP/faultmgmt/0/faults/0
Properties:
class = fault.chassis.device.battery.low
sunw-msg-id = DCSIB-8000-45
uuid = 82e90599-8650-47dc-b613-1e602607441b
timestamp = 2002-01-01/00:07:27
fru_part_number = 3002234
fru_serial_number = 006541
product_serial_number = AK00022680
chassis_serial_number = AK00022680
->If the battery is faulty, replace it. See Replace the Battery.
If you do not see the word battery, or if a FRU value in addition to or different from /SYS/MB is displayed in Step a, see Clearable Fault Targets to identify which component is faulty.
If no Oracle ILOM targets are listed in Step a, go to Step 4.
-> show /SYS/MB/V_BAT value
/SYS/MB/V_BAT
Properties:
value = 3.136 Volts
