Skip Navigation Links
Exit Print View
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Access to Oracle Support
Installation
Understanding the Switch
Switch Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
NET MGT Connector and Pins
InfiniBand QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding InfiniBand Cabling
Preparing to Install the Switch
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Optical Fiber InfiniBand Cables
Route the InfiniBand Cables
Installing the Switch
Install the Switch in the Rack
Powering On the Switch
Connecting InfiniBand cables
Administration
Troubleshooting the Switch
Switch Hardware Problems
InfiniBand Fabric Problems
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Switch GUIDs Overview
Configuration Overview
Oracle ILOM Command Overview
Hardware Command Overview
InfiniBand Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring Secure Fabric Management
Remote Management
Understanding Oracle ILOM on the Switch
Oracle ILOM Overview
Supported Features
CLI Overview
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Switch Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Switch Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (Oracle ILOM)
help Command (Oracle ILOM)
load Command
reset Command
set Command
show Command
version Command (Oracle ILOM)
Service
Detecting and Managing Faults
Interpreting Status LEDs
Front Panel LEDs
Rear Panel LEDs
Check Chassis Status LEDs
Check NET MGT Port Status LEDs
Check Link Status LEDs
Check Power Supply Status LEDs
Check Fan Status LEDs
Managing Faulty Components
Display Faulty Components (fault_state)
Display Faulty Components (/SP/faultmgmt)
Clear a Fault Manually
Clearable Fault Targets
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Display the General Alarm State of Systems and Components
System Alarm Targets
Component Alarm Targets
Oracle ILOM Target Alarm States
Evaluating Sensor Alarms
Display Oracle ILOM Sensor Status
Determine Oracle ILOM Sensor Target Types
Evaluating a Voltage Sensor Alarm
Evaluate a Voltage Sensor
Voltage Sensor Values
Voltage Out of Range
Evaluating a Temperature Sensor Alarm
Evaluate a Temperature Sensor
Temperature Sensor Values
Temperature Out of Range
Evaluating a Speed Sensor Alarm
Evaluate a Speed Sensor
Speed Sensor Values
Speed Out of Range
Evaluating a State Sensor Alarm
Evaluate a State Sensor
State Sensor Alarm Conditions
Evaluating a Presence Sensor Alarm
Evaluate a Presence Sensor
Presence Sensor Alarm Conditions
Evaluating an Indicator State
Evaluate an Indicator State
Indicator State Values
Indicator State Conditions
Accessing CLI Prompts
Access the Oracle ILOM CLI (NET MGT Port)
Enter the Restricted Linux Shell
Exit the Restricted Linux Shell
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Determine If a Power Supply Is Faulty
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Determine If a Fan Is Faulty
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing InfiniBand Cables
Inspecting the InfiniBand Cables
Remove an InfiniBand Cable
Install an InfiniBand Cable
Servicing the Battery
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Replace the Battery
Reference
autodisable Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
create_ipoib Command
createfabric Command
dcsport Command
delete_ipoib Command
disablecablelog Command
disablelinklog Command
disablesm Command
disableswitchport Command
enablecablelog Command
enablelinklog Command
enablesm Command
enableswitchport Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
localmkeypersistence Command
matchtopology Command
setcontrolledhandover Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsmrouting Command
setsubnetprefix Command
showdisk Command
showfree Command
showfruinfo Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
smconfigtest Command
smnodes Command
smpartition Command
smsubnetprotection Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
Index
Even though all voltages within the chassis are regulated, situations can arise where a voltage drifts outside of the acceptable range and goes too high or too low.
When a voltage is too high, it can be caused by:
For example, if the voltage at sensor target /SYS/MB/V_I41.2V is too high, then either the regulator is failing, or the I4 switch chip is no longer requiring the supplied voltage. This latter situation can occur transitionally if the I4 switch chip is reset or if all of its ports are disabled. If the I4 switch chip has a catastrophic failure, such as from overheating, the voltage at the sensor target might go too high.
When a voltage is too low, it can be caused by:
For example, if the voltage at sensor target /SYS/MB/V_I41.2V is too low, then either the regulator is failing, or the I4 switch chip is under very heavy throughput loading, quite possibly in conjunction with overheating.
Because both types of voltage extremes for the /SYS/MB/V_I41.2V sensor target can be indicative of a thermal problem with the I4 switch chip, it follows that a check of the temperature at sensor target /SYS/MB/T_I4A, is in order.
Note - The 3.3VMain, 3.3VStby, and the 12V are provided by the power supplies redundantly. If one of these voltages is either too high or too low, one or both of the power supplies could be at fault, as the voltages are provided by the power supplies in parallel. Because of this configuration, you must recheck the 3.3VMain, 3.3VStby, and 12V with only one power supply operational at a time. Re-perform Display Oracle ILOM Sensor Status with only the power cord for PSU0 disconnected, and then again with only the power cord for PSU1 disconnected.
Related Information
