Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
V1 and V2c Protocol Command Format
Display the Date and Time (SNMP)
Display the Aggregate Sensors State (SNMP)
Display Power Supply Status (SNMP)
Display Board-Level Voltages (SNMP)
Display the Sensor Alarm State (SNMP)
Display Oracle ILOM Sessions (SNMP)
Display the Oracle ILOM Event Log (SNMP)
Checking the Status of Services (SNMP)
Display the HTTP Service Status (SNMP)
Display the HTTPS Service Status (SNMP)
Display the DNS Client Status (SNMP)
Display the SMTP Client Status (SNMP)
Display the NTP Servers (SNMP)
Verifying Other Aspects With Oracle ILOM (SNMP)
Display the Alert Properties (SNMP)
Display Oracle ILOM User Accounts (SNMP)
Display the Remote Log Hosts (SNMP)
Display the Network Management Configuration (SNMP)
Display Power Supply FRU ID (SNMP)
Display the System Components (SNMP)
Display the Additional System Component Information (SNMP)
Display the Firmware Version (SNMP)
Display System Identification Properties (SNMP)
Performing General Tasks (SNMP)
Set the Network Time Protocol State (SNMP)
Set the Network Time Protocol Servers (SNMP)
Clear the Oracle ILOM Event Log (SNMP)
Set the Remote Log Hosts (SNMP)
Configure the DNS Client (SNMP)
Configure the SMTP Client (SNMP)
Set the Network Parameters (SNMP)
Set the System Identification Properties (SNMP)
Add an Oracle ILOM User Account (SNMP)
Delete an Oracle ILOM User Account (SNMP)
Managing Other Aspects With Oracle ILOM (SNMP)
Set the HTTP Service State (SNMP)
Set the HTTPS Service State (SNMP)
Enable Alerts to Send SNMP Traps (SNMP)
Enable Alerts to Send PETs (SNMP)
Enable Alerts to Send Email Alerts (SNMP)
Modify Alert SNMP Version (SNMP)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Note - The entity numbers used in this procedure are for example only. Your entity numbers might differ, depending on the switch firmware and configuration.
Note - The temperature values displayed for this procedure are in degrees celsius.
$ snmpget -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.number
where number is the entity number.
For example, to display the current I4 switch chip temperature, use the entity number respective to the /SYS/MB/T_I4A temperature sensor target. This example uses entity number 21.
$ snmpget -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.21 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.21 = INTEGER: 36 $
The I4 switch chip temperature displayed in the output of the example is 36 degrees celsius.
Note - Temperature readings can vary and are influenced by the switch environment and loading.
$ snmpwalk -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorTable SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.4 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.6 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.7 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.8 = INTEGER: volts(6) . . . SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.17 = INTEGER: degC(3) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.18 = INTEGER: degC(3) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.19 = INTEGER: degC(3) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.21 = INTEGER: degC(3) . . . SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.17 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.18 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.19 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.21 = INTEGER: 0 . . . SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.17 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.18 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.19 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.21 = INTEGER: none(1) . . . SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.17 = INTEGER: 28 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.18 = INTEGER: 28 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.19 = INTEGER: 42 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.21 = INTEGER: 31 . . . SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.17 = INTEGER: reset(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.18 = INTEGER: reset(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.19 = INTEGER: reset(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.21 = INTEGER: reset(1) . . . $
You can also filter the output of the snmpwalk command for a specific entity number. This is an example of filtering the snmpwalk command output.:
$ snmpwalk -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorTable |grep -F '.number ='
Note - The manner in which you can filter the output varies according to your operating system.
To filter temperature information for the I4 switch chip, use the entity number respective to the /SYS/MB/T_I4A temperature sensor target. This filtering example uses entity number 21:
$ snmpwalk -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorTable |grep -F '.21 =' SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.21 = INTEGER: degC(3) SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.21 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.21 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.21 = INTEGER: 36 SUN-PLATFORM-MIB::sunPlatNumericSensorNormalMin.21 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorNormalMax.21 = INTEGER: 255 SUN-PLATFORM-MIB::sunPlatNumericSensorAccuracy.21 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorLowerThresholdNonCritical.21 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorUpperThresholdNonCritical.21 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorLowerThresholdCritical.21 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorUpperThresholdCritical.21 = INTEGER: 70 SUN-PLATFORM-MIB::sunPlatNumericSensorLowerThresholdFatal.21 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorUpperThresholdFatal.21 = INTEGER: 100 SUN-PLATFORM-MIB::sunPlatNumericSensorHysteresis.21 = Gauge32: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorEnabledThresholds.21 = BITS: 14 upperThresholdCritical(3) upperThresholdFatal(5) SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.21 = INTEGER: reset(1) $
