Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Display the Switch Chip Port to QSFP Connector Mapping
Locate an InfiniBand Device and Connector From the GUID and Port
Locate a Switch Chip or Connector From the GUID and Port
Display Switch Chip Boot Status
Display Connectors Configured With Autodisable Functionality
Display Switch Chip Port Status
Display Switch Chip Port Counters
Autodisabling Ports and Connectors
Add Connectors to the Autodisable List
Reenable Autodisabled Connectors
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
FabMan@switch_name->autodisable del connector cause
where:
connector is the name of the connector (0A to 17A and 0B to 17B).
cause is the reason to disable the connector:
H – The error rate is higher than what the InfiniBand specification permits.
L – The link speed or width is less than optimal (less than 4x QDR).
Alternatively, to delete all connectors, type.
FabMan@switch_name->autodisable none
In this situation, all connectors are deleted from the autodisable list regardless of cause.
For example, to delete connector 0A from the autodisable list for suboptimal link width:
FabMan@switch_name->autodisable del 0A L FabMan@switch_name->
Switch Reference, autodisable command
