Choose one of the following methods to specify service processor (SP) network settings:
BIOS – Assign the IP address for the server SP from the BIOS Setup Utility on the Advanced Menu.
Oracle ILOM – For instructions on setting the IP address for the server SP using Oracle ILOM, refer to the Oracle Integrated Lights Out Manager (ILOM) 5.0 Documentation Library at https://www.oracle.com/goto/ilom/docs.
Oracle System Assistant – For instructions on using Oracle System Assistant to configure SP network settings, refer to Oracle X5 Series Servers Administration Guide at https://www.oracle.com/goto/x86admindiag/docs.
The Advanced Menu screen appears.
The BMC Network Configuration screen appears.
The BMC is the Baseboard Management Controller.
The BMC Network Configuration screen refreshes. Scroll down to review BMC network settings.
