Go to main content
oracle home
Oracle
Server X5-2L Service Manual
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Oracle Server X5-2L Documentation Library
Oracle
Server X5-2L Service ...
Remove Antistatic Measures
Updated: January 2021
Oracle
Document Information
Using This Documentation
Product Documentation Library
Feedback
About the Oracle Server X5-2L
Product Description
About Controls and Connectors
Front Panel Components on Eight Drive Systems
Front Panel Components on Twelve Drive Systems
Front Panel Components on Twenty-Four Drive Systems
Rear Panel Components and Cable Connections
About System Components
Illustrated Parts Breakdown
Customer-Replaceable Units
Field-Replaceable Units
Troubleshooting and Diagnostics
Troubleshooting Server Component Hardware Faults
Troubleshooting Server Hardware Faults
Basic Troubleshooting Process
Related Information
Troubleshoot Hardware Faults Using the Oracle ILOM Web Interface
Troubleshooting and Diagnostic Information
Troubleshooting Using the Server Front and Rear Panel Status Indicators
Related Information
Server Boot Process and Normal Operating State Indicators
Server System-Level Status Indicators
Server Fan Status Indicators
Storage and Boot Drive Indicators
Power Supply Status Indicators
Network Management Port Status Indicators
Ethernet Ports Status Indicators
Motherboard Status Indicators
Troubleshooting System Cooling Issues
External Ambient Temperature Too High
Airflow Blockage
Cooling Areas Compromised
Hardware Component Failure
Troubleshooting Power Issues
AC Power Connection
Power Supplies (PSUs)
Top Cover
Managing Server Hardware Faults Through the Oracle ILOM Fault Management Shell
Troubleshooting With Diagnostic Tools
Diagnostic Tools
Diagnostic Tool Documentation
Attaching Devices to the Server
Attach Devices to the Server
Rear Panel Connector Locations
Configuring Serial Port Sharing
Assign Serial Port Output Using the CLI
Assign Serial Port Output Using the Web Interface
Server Operating System Names for the NVMe Storage Drives
Ethernet Port Boot Order and Device Naming
Ethernet Port Device Naming
Rear Panel Pinhole Switches
Getting Help
Contacting Support
Related Information
Locating the Chassis Serial Number
Preparing for Service
Safety Precautions
Safety Symbols
Electrostatic Discharge Safety
FRU Key Identity Properties (KIP) Automated Update
Related Information
Required Tools
Preparing the Server for Component Replacement
Powering Down the Server
Power Down the Server Gracefully Using the Oracle ILOM CLI
Power Down the Server Gracefully Using the Oracle ILOM Web Interface
Power Down the Server Gracefully Using the Power Button
Power Down the Server for Immediate Shutdown Using the Power Button
Power Down the Server for Immediate Shutdown Using the Oracle CLI
Power Down the Server for Immediate Shutdown Using the Oracle ILOM Web Interface
Disconnect Cables From the Server
Extend the Server to the Maintenance Position
Remove the Server From the Rack
Take Antistatic Measures
Remove the Server Top Cover
Remove the Fan Assembly Door From the Server
Remove the Disk Cage Cover From the Server
Servicing CRUs That Do Not Require Server Power-Off
Servicing Storage Drives and Rear Drives (CRU)
Storage Drives Hot-Plug Conditions
Storage Drive Failure and RAID
Removing and Replacing an HDD or SSD Storage Drive
Remove an HDD or SSD Storage Drive
Install an HDD or SSD Storage Drive
Removing and Replacing an NVMe Storage Drive Using Oracle Solaris
Unmount an NVMe Storage Drive
Remove an NVMe Storage Drive From the Server
Verify Removal of an NVMe Storage Drive
Install an NVMe Storage Drive in the Server
Power On an NVMe Storage Drive and Attach a Device Driver
Related Information
Removing and Replacing an NVMe Storage Drive Using Oracle Linux
Verify Operation of an NVMe Storage Drive
Related Information
Removing and Replacing a Rear Storage Drive
Remove a Rear Storage Drive
Install a Rear Storage Drive
Servicing Fan Modules (CRU)
Remove a Fan Module
Install a Fan Module
Servicing Power Supplies (CRU)
Remove a Power Supply
Install a Power Supply
Servicing CRUs That Require Server Power-Off
Servicing the DIMMs (CRU)
DIMM and Processor Physical Layout
DIMM Population Scenarios
Related information
DIMM Population Rules
Populating DIMMs for Optimal System Performance
Populating DIMMs in Single-Processor Systems for Optimal System Performance
Populating DIMMs in Dual-Processor Systems for Optimal System Performance
DIMM Operating Speeds
DIMM Rank Classification Labels
Inconsistencies Between DIMM Fault Indicators and the BIOS Isolation of Faulty DIMMs
Using the Server Fault Remind Button
Identify and Remove a Faulty DIMM
Install a DIMM
Servicing PCIe Cards (CRU)
PCIe Slot Locations
Remove a PCIe Card
Install a PCIe Card
Servicing the Internal USB Flash Drives (CRU)
Servicing the Oracle System Assistant USB Flash Drive
Remove an Internal USB Flash Drive
Install an Internal USB Flash Drive
Servicing the Battery (CRU)
Remove the Battery
Install the Battery
Servicing FRUs
Servicing Processors (FRU)
Selecting the Correct Processor Removal and Replacement Tool
Remove a Processor
Install a Processor
Servicing the Front and Rear Storage Drive Backplanes (FRU)
Remove the Storage Drive Backplane for Eight-Drive Systems
Install the Storage Drive Backplane for Eight-Drive Systems
Remove the Storage Drive Backplane for Twelve-Drive Systems
Install the Storage Drive Backplane for Twelve-Drive Systems
Remove the Storage Drive Backplane for Twenty-Four Drive Systems
Install the Storage Drive Backplane for Twenty-Four Drive Systems
Remove the Storage Drive Backplane for Rear-Mounted Storage Drives
Install the Storage Drive Backplane for Rear-Mounted Storage Drives
Servicing SAS Cables (FRU)
Remove SAS Storage Drive Cables
Install SAS Storage Drive Cables
Servicing NVMe Cables (FRU)
Related Information
Remove NVMe Cables
Install NVMe Cables
Servicing the Oracle Storage 12 Gb/s SAS PCIe RAID HBA Card (FRU)
Remove the Oracle Storage 12 Gb/s SAS PCIe RAID HBA Card
Install the Oracle Storage 12 Gb/s SAS PCIe RAID HBA Card
Servicing the DVD Drive (FRU)
Remove the DVD Drive
Install the DVD Drive
Servicing the Front LED/USB Indicator Modules (FRU)
Remove the Left LED Indicator Module
Install the Left LED Indicator Module
Remove the Right LED/USB Indicator Module
Install the Right LED/USB Indicator Module
Servicing the Motherboard Assembly (FRU)
Remove the Motherboard Assembly
Install the Motherboard Assembly
Server Filler Panel Requirements
Remove and Install Filler Panels
Install the Server Top Cover
Install the Fan Assembly Door
Install the Disk Cage Cover
Reinstall the Server in the Rack
Return the Server to the Normal Rack Position
Reconnect Power and Data Cables
Power On the Server
Identifying the Server Ports
Gigabit Ethernet Ports
Serial Management Port
Video Connector
USB Ports
Setting Up BIOS Configuration Parameters
Managing the BIOS Configuration
Accessing the BIOS Setup Utility
BIOS Setup Utility Menus
BIOS Key Mappings
Access BIOS Setup Utility Menus
Navigate BIOS Setup Utility Menus
Using UEFI
Selecting Legacy BIOS or UEFI Boot Mode
Switching Between Legacy BIOS and UEFI Boot Modes
UEFI Boot Mode Advantages
Configuration Utilities for Add-In Cards
Using BIOS for Resource Allocation
Legacy Option ROM Allocation
Common BIOS Setup Utility Tasks
Verify BIOS Factory Default Settings
Select Legacy BIOS or UEFI BIOS Boot Mode
Select the Boot Device
Enable or Disable Oracle System Assistant
Configure TPM Support
Configure SP Network Settings
Configure Option ROM Settings
Configure I/O Resource Allocation
Exit BIOS Setup Utility
BIOS Setup Utility Menu Options
BIOS Main Menu Selections
BIOS Advanced Menu Selections
BIOS Advanced Menu Processor Configuration Options
BIOS Advanced Menu CPU Power Management Configuration Options
BIOS Advanced Menu Memory Configuration Option
BIOS Advanced Menu USB Ports Options
BIOS Advanced Menu Serial Port Console Redirection Options
BIOS Advanced Menu Trusted Computing Options
BIOS Advanced Menu Network Stack Options
BIOS Advanced Menu BMC Network Configuration Options
BIOS Advanced Menu iSCSI Configuration Options
BIOS Advanced Menu Ethernet Controller Options
BIOS IO Menu Selections
BIOS IO Menu PCI Subsystem Settings Options
BIOS IO Menu IO Virtualization Options
BIOS IO Menu I/OAT Configuration Options
BIOS IO Menu Internal Devices Options
BIOS IO Menu Add In Cards Options
BIOS Boot Menu Selections
BIOS Exit Menu Selections
Monitoring Components and Identifying SNMP Messages
Monitoring Component Health and Faults Using Oracle ILOM
Monitoring System Components
System Chassis Components
Cooling Unit Components
Disk Backplane Components
Memory Device Components
Power Unit Components
Processor Components
System Board Components
System Firmware Components
Hard Disk Drive Components
Identifying SNMP Trap Messages
Environmental Events
Hard Disk Drive Events
Power Events
Fan Events
Memory Events
Entity Presence Events
Physical Security Events
Index
Index A
Index B
Index C
Index D
Index E
Index F
Index G
Index H
Index I
Index L
Index M
Index N
Index O
Index P
Index R
Index S
Index T
Index U
Index V
Index W
Language:
English
Remove any antistatic straps or conductors from the server chassis.
Remove the antistatic wrist strap from yourself.
Related Information
Previous
Next
