Serial Management Port
The serial management connector (labeled SER MGT) is an RJ-45 connector that can be
accessed from the rear panel. This port is the default connection to the server. Use this
port only for server management.
Table 15 Default Serial Connections for Serial Port
Connector
SER MGT
Rate
9600 baud
Parity
None
Stop bits
1
Data bits
8
The following figure and table describe the SER MGT port pin signals.
Table 16 Serial Management Port Signals
1
Request to Send
5
Ground
2
Data Terminal Ready
6
Receive Data
3
Transmit Data
7
Data Set Ready
4
Ground
8
Clear to Send
If you need to connect to the SER MGT port using a cable with either a DB-9 or
a DB-25 connector, follow the pin descriptions in the tables to create a crossover adapter
appropriate for your serial connection.
Table 17 RJ-45 to DB-9 Adapter Crossovers Wiring Reference
1
RTS
8
CTS
2
DTR
6
DSR
3
TXD
2
RXD
4
Signal ground
5
Signal ground
5
Signal ground
5
Signal ground
6
RXD
3
TXD
7
DSR
4
DTR
8
CTS
7
RTS
Table 18 RJ-45 to DB-25 Adapter Crossovers Wiring Reference
1
RTS
5
CTS
2
DTR
6
DSR
3
TXD
3
RXD
4
Signal ground
7
Signal ground
5
Signal ground
7
Signal ground
6
RXD
2
TXD
7
DSR
20
DTR
8
CTS
4
RTS
