Go to main content
Oracle® Server X5-2L Service Manual
Exit Print View
Updated: January 2021
Servicing the Battery (CRU)
The real-time clock (RTC) battery maintains system time when the server is powered off and a time server is unavailable. If the server fails to maintain the proper time when the system is powered off and not connected to a network, replace the battery.
Caution
Caution  -  Ensure that all power is removed from the server before removing or installing the battery. You must disconnect the power cables from the system before performing this procedure.
This section covers the following procedures:
