Go to main content
Oracle® Server X5-2L Service Manual
Exit Print View
Updated: January 2021
After replacing components inside of the server, perform the procedures in the following sections.
Description
Links
Note server filler panel requirements.
Install the server top cover.
Install the fan door assembly top cover.
Install the disk cage cover.
Remove any antistatic measures.
Reinstall the server chassis in the rack.
Return the server to the normal rack position.
Reconnect power and data cables.
Power on the server.
Related Information
