Go to main content
Oracle® Server X5-2L Service Manual
Exit Print View
Updated: January 2021
Memory Events
The following table lists memory events.
Messages and Descriptions
Component Name
SNMP Trap: sunHwTrapSensorNonCritThresholdExceeded
Oracle ILOM Event Message: Upper noncritical threshold exceeded
Severity and Description: Minor; A sensor has reported that its value has gone above an upper non critical threshold setting or below a lower non critical threshold setting. This generic 'sensor' trap is generated when the SNMP agent does not recognize the component type.
The sunHwTrapThresholdType object indicates whether the threshold was an upper or lower.
/SYS/VPS_CPUS
/SYS/VPS_MEMORY
SNMP Trap: sunHwTrapSensorThresholdOk
Oracle ILOM Event Message: Upper noncritical threshold no longer exceeded
Severity and Description: Informational; A sensor has reported that its value is in the normal operating range. This generic 'sensor' trap is generated when the SNMP agent does not recognize the component type.
/SYS/VPS_CPUS
/SYS/VPS_MEMORY
SNMP Trap: sunHwTrapMemoryFault
Oracle ILOM Event Message: event fault.cpu.intel.quickpath.link_slow "The Quickpath Interconnect (QPI) link is operating below normal speed."
Severity and Description: Major; A memory component is suspected of causing a fault.
/SYS/MB
SNMP Trap: sunHwTrapMemoryFaultCleared
Severity and Description: Informational; A memory component fault has been cleared.
/SYS/MB
Oracle ILOM Event Message: event fault.cpu.intel.quickpath.unknown-errcode "An unknown error code from the Quickpath Interconnect (QPI) reference code has been detected."
/SYS/MB
/SYS/MB
Oracle ILOM Event Message: event fault.memory.intel.dimm.none "An invalid memory DIMM configuration has been detected."
/SYS/MB
/SYS/MB
Oracle ILOM Event Message: event fault.memory.intel.dimm.memtest-failed "All memory channels have been disabled due to memory test failures."
/SYS/MB
/SYS/MB
Oracle ILOM Event Message: event fault.memory.intel.dimm.quadrank-3rd-slot "A quad-rank memory DIMM has been installed in the third slot of a memory channel."
/SYS/MB
/SYS/MB
Oracle ILOM Event Message: event fault.memory.intel.dimm.ddr3u-unsupported "An unsupported DDR3 ultra low voltage memory DIMM has been detected."
/SYS/MB
/SYS/MB
Oracle ILOM Event Message: event fault.memory.intel.mrc.unknown-errcode "An unknown error code from the Memory Reference Code (MRC) has been detected."
/SYS/MB
/SYS/MB
Oracle ILOM Event Message: event fault.memory.intel.dimm.udimm-unsupported "An unbuffered memory DIMM (UDIMM) has been detected."
/SYS/MB/P[0-x]/D[0-11]
Oracle ILOM Event Message: event fault.memory.intel.dimm.sodimm-unsupported "An unsupported SODIMM has been detected in system."
Oracle ILOM Event Message: event fault.memory.intel.dimm.4gb-fused "An unsupported 4-gb memory DIMM has been detected."
Oracle ILOM Event Message: event fault.memory.intel.dimm.8gb-fused "An unsupported 8-gb memory DIMM has been detected."
Oracle ILOM Event Message: event fault.memory.intel.dimm.incompatible "A memory DIMM is incompatible with the memory controller."
Oracle ILOM Event Message: event fault.memory.intel.dimm.incompatible-maxranks "The number of ranks allowed on a memory channel has been exceeded."
Oracle ILOM Event Message: event fault.memory.intel.dimm.incompatible-quadrank "An invalid quad-rank memory DIMM configuration has been detected."
Oracle ILOM Event Message: event fault.memory.intel.dimm.numranks-unsupported "A memory DIMM with an unsupported number of ranks has been detected."
Oracle ILOM Event Message: event fault.memory.intel.dimm.speed-slow "A memory DIMM has been detected that is unable to run at speeds required by the platform."
Oracle ILOM Event Message: event fault.memory.intel.dimm.disable-quadrank "Memory channel is populated with too many quad-rank memory DIMMs."
Oracle ILOM Event Message: event fault.memory.intel.dimm.population-invalid "Memory DIMM is improperly populated or is a type that is not compatible with other DIMMs installed."
Oracle ILOM Event Message: event fault.memory.intel.dimm.out-of-order "The memory DIMMs in a channel are not populated in sequential order."
Oracle ILOM Event Message: event fault.memory.intel.dimm.category-unknown "Memory DIMM is of an unknown type or category."
Related Information
