Rack units |
2U |
2U |
Height
3.43 in.
87.1 mm
Width (chassis)
Maximum Width (from bezel front to rear protrusions)
16.75 in.
17.52 in.
425.45 mm
445 mm
Depth (chassis)
Maximum Depth (from bezel front to rear protrusions)
24 in.
25.2 in.
609.6 mm
640 mm
Weight (fully configured without PCIe cards)
45 lb
20.45kg
Minimum service clearance (front) |
36 in. |
914.4 mm |
Minimum service clearance (rear) |
36 in. |
914.4 mm |
Minimum airflow clearance (front) |
2 in. |
50.8 mm |
Minimum airflow clearance (rear) |
3 in. |
76.2 mm |
