Processor
One or two socket Intel Haswell-EP, E5-2699v3 CPU, 18-core,
dual-thread, 145W TDP max, non-throttling.
Memory
The number of DIMM slots depends on the CPU configuration.
Single Processor
– 12 DDR4, 2133 MHz, RDIMMs or LRDIMMs DIMM slots that
support 16 GB RDIMM or 32 GB LRDIMM capacities.
Dual Processor –
24 DDR4, 2133 MHz, RDIMMs or LRDIMMs DIMM slots (12 DIMM
slots per CPU) that support 16 GB RDIMM or 32 GB LRDIMM
capacities.
Note -
The quantity and capacity of installed memory varies based on
what was ordered.
Storage
Depending on the model, one of the following
configurations:
Six SFF slots with SAS HDDs or flash drives and a SATA-3
DVD-RW
Two SFF slots with SAS HDDs or flash drives and 4x SFF
slots with NVMe HDDs and a SATA-3 DVD-RW
Eight SFF slots with SAS HDDs or flash drives and no SATA
DVD-RW
Four SFF slots with SAS HDDs or flash drives and 4x SFF
slots with NVMe HDD and no SATA-3 DVD-RW
Note -
The total number of drives and storage capacity varies based
on what was ordered, with a maximum capacity of either six or
eight 600-GB drives.
Optical media
Only available in the 6-drive model: One tray-loading,
slimline SATA DVD drive, supporting CD-R/-RW, CD+R/+RW,
DVD-R/-RW, DVD+R/+RW (when used with supported
media).
Service processor
Internal Pilot3 BMC running Oracle ILOM service processor firmware
with provisions for:
Oracle ILOM 3.2.4
2D graphics (HD-15 VGA connector)
Serial management (RJ-45)
Network management (10/100/1000BASE-T Ethernet
RJ-45)
Complete host remote management, including remote KVMS
over Ethernet
Out-of-band host BIOS flash updates
Ethernet ports
Four 100/1000Mb/10Gb BASE-T Ethernet (RJ-45) with integrated
link/speed LEDs.
PCIe slots
The number of available PCIe slots depends on the CPU
configuration.
Single Processor
– One x8 PCIe Gen3 slot (slot 6) and one x16 PCIe Gen3
slot (slot 5). Both PCIe expansion slots support PCIe 3.0 /
Gen3 (PCIe3) signaling levels, and can support both Gen2 and
legacy Gen1 compliant option cards.
Dual Processor –
Four x8 PCIe Gen3 slots and two x16 Gen3 slots. All PCIe
expansion slots support PCIe 3.0 / Gen3 (PCIe3) signaling
levels, and can support both Gen2 and legacy Gen1 compliant
option cards.
USB ports
Six USB ports: two on front panel (USB 2.0), two on rear panel
(USB 3.0), and two internal on motherboard (USB 2.0).
Note -
Internal USB port 0 is preinstalled with a USB drive
containing OSA.
Indicators and switches
Power button switch
Locate button switch with integrated LED
System OK LED
System Fault LED
Alarm LEDs - Critical, Major, Minor, and User
SP LED
Rear PS fault LED
Power supplies
configurations:
Note -
Mixing of AC and DC power supplies is not allowed.
Cooling
Front-to-back forced air, with active fan speed control.
