Electrical Specifications
The values in this table are for the power supplies. Use the online power calculator
to determine the power consumption of a server with your configuration: http://www.oracle.com/goto/powercalculators.
Voltage (nominal)
100 VAC (Japan only)
110 to 127 (90 to 132 range)
200 to 240 VAC (180 to 264 VAC range)
−48 or −60 VDC (−40 to −72 VDC
range)
Input current (maximum)
10A @ 100 VAC
9A @ 110-127 VAC
5.5A @ 200-240 VAC
21.5A @ −48 VDC
17A @ −60VDC
Frequency (nominal)
50/60 Hz (47 to 63 Hz range)
N/A
DC input treatment
N/A
Isolated DC Return (DC-I)
 | Caution -
The ports of this equipment or subassembly are suitable for connection to
intra-building or unexposed wiring or cabling only. The intra-building port(s) of
the equipment or subassembly must not be metallically connected to interfaces that
connect to the outside plant wiring. These interfaces are designed for use as
intra-building interfaces only (Type 2 or Type 4 ports as described in GR-1089-CORE,
Issue 6) and require isolation from the exposed outside plant cabling. The addition
of primary protectors is not sufficient protection in order to connect these
interfaces metallically to outside plant wiring.
 | Caution -
The intra-building port(s) of the equipment or subassembly must use
shielded intra-building cabling or wiring that is grounded at both ends, except the ethernet ports.
