PIM is disabled in the system, by default. Complete the following task to enable PIM.
SEFOS# configure terminal SEFOS(config)# set ip pim enable SEFOS(config)# end
SEFOS# show ip pim component PIM Component Information --------------------------- Component-Id: 1 PIM Mode: sparse, PIM Version: 2 Elected BSR: 0.0.0.0 Candidate RP Holdtime: 0
