LAN prune delay is disabled in the system by default. This example configures VLAN 5 as a BSR candidate with a preference value of 20. VLAN 5 is used as the BSR unless another router is identified as a BSR candidate with a higher bsr-candidate value.
SEFOS# configure terminal SEFOS(config)# set ip pim enable
SEFOS(config)# interface vlan 5
SEFOS(config-if)# ip pim componentId 1
SEFOS(config-if)# ip pim query-interval 60
SEFOS(config-if)# ip pim bsr-candidate 20 SEFOS(config-if)# end
SEFOS# show ip pim bsr PIMv2 Bootstrap Configuration For Component 1 ------------------------------------------------ This system is the PIMv4 Bootstrap Router (BSR) BSR Address : 10.1.0.1 BSR Priority : 20, Hash Mask Length : 30
