Enable Static RP
Static RP is disabled in the system, by default.
Complete the following task to enable static RP.
- Enable
a static RP.
SEFOS# configure terminal
SEFOS(config)# set ip pim enable
SEFOS(config)# set ip pim static-rp enable
SEFOS# end
- Ensure that the static RP has
been enabled.
SEFOS# show ip pim rp-static
Static-RP Enabled
