After configuring a static RP, you can view the group prefix, RP address, and hold and expiration times for the interface.
SEFOS# configure terminal SEFOS(config)# set ip pim static-rp enable SEFOS(config)# interface vlan 5 SEFOS(config-if)# ip pim componentId 1
SEFOS(config-if)# ip pim query-interval 60
SEFOS(config-if)# ip pim bsr-candidate 30 SEFOS(config-if)# exit
SEFOS(config)# ip pim component 1 SEFOS(pim-comp)# rp-candidate holdtime 30 SEFOS(pim-comp)# rp-candidate rp-address 224.1.0.0 255.255.0.0 10.1.0.1 SEFOS(pim-comp)# end
SEFOS(pim-comp)# rp-static rp-address 224.1.0.0 255.255.0.0 10.1.0.1 SEFOS(pim-comp)# end
SEFOS# show ip pim rp-set
PIM Group-to-RP mappings
Group Address : 224.1.0.0 Group Mask : 255.255.0.0
RP: 10.1.0.1
Component-Id : 1
Hold Time : 30, Expiry Time : 00:00:19
