PMBR status reporting is disabled by default.
This example enables PMBR status for VLAN 5. In addition, the PIM component is configured in the router as component 1.
SEFOS# configure terminal SEFOS(config)# set ip pim enable SEFOS(config)# set ip pim pmbr enable
SEFOS# interface vlan 5 SEFOS(config-if)# ip pim componentId 1 SEFOS(config-if)# end
SEFOS# show ip pim interface detail Vlan5 33 is up Internet Address is 10.1.0.1 Muticast Switching : Enabled PIM : Enabled PIMv6 : Disabled PIM version : 2, mode: Sparse PIM DR : 10.1.0.1 PIM DR Priority : 1 PIM Neighbour Count : 0 PIM Hello/Query Interval : 30 PIM Message Interval : 60 PIM Override Interval : 0 PIM Lan Delay : 0 PIM Lan-Prune-Delay : Disabled PIM Component Id : 1 PIM domain border : enabled
