This example advertises 10.1.0.2 as a static RP on PIM component 1, with a group address of 224.1.0.0 and a group mask of 255.255.0.0.
SEFOS# configure terminal SEFOS(config)# set ip pim enable
SEFOS(config)# set ip pim static-rp enable SEFOS(config)# interface vlan 5 SEFOS(config-if)# ip pim componentId 1
SEFOS(config-if)# ip pim query-interval 60 SEFOS(config-if)# exit SEFOS(config)#
SEFOS(config)# ip pim component 1
SEFOS(pim-comp)# rp-static rp-address 224.1.0.0 255.255.0.0 10.1.0.2 SEFOS(pim-comp)# end SEFOS#
SEFOS# show ip pim rp-static 1
Static-RP Enabled
CompId GroupAddress Group Mask RPAddress
1 224.1.0.0 255.255.0.0 10.1.0.2
