You can view the component ID, the multicast group address used by the listed RP, the network address for the source of the multicast routing information, and a summary of the mroute information.
SEFOS# configure terminal SEFOS(config)# set ip pim enable
SEFOS(config)# interface vlan 5
SEFOS(config-if)# ip pim componentId 1
SEFOS(config-if)# ip pim query-interval 60 SEFOS(config-if)# exit SEFOS(config)#
SEFOS(config)# interface vlan 5 SEFOS(config-if)# ip pim bsr-candidate 30 SEFOS(config-if)# exit
SEFOS(config)# ip pim component 1 SEFOS(pim-comp)# rp-candidate holdtime 30 SEFOS(pim-comp)# rp-candidate rp-address 224.1.0.0 255.255.0.0 10.1.0.1 SEFOS(pim-comp)# exit
SEFOS(config)# interface vlan 5 SEFOS(config)# set ip pim static-rp enable SEFOS(config)# ip pim component 1
SEFOS(config)# ip pim component 1 SEFOS(pim-comp)# rp-static rp-address 224.1.0.0 255.255.0.0 10.1.0.1 SEFOS(pim-comp)# exit
SEFOS(config)# set ip igmp enable SEFOS(config)# interface vlan 5 SEFOS(config-if)# set ip igmp enable SEFOS(config-if)# end
Send the IGMP v2 report with a source IP of 10.1.0.10.
SEFOS# show ip pim mroute
IP Multicast Routing Table
Route Flags S: SPT Bit W: Wild Card Bit R: RPT Bit
Timers: Uptime/Expires
Interface State: Interface, State/Mode
PIM Multicast Routing Table For Component 1
(*, 224.1.0.0) ,00:03:53/--- ,RP : 10.1.0.1
Incoming Interface : Vlan5 ,RPF nbr : NULL ,Route Flags : WR
Outgoing InterfaceList :
Vlan5, Forwarding/Sparse ,00:03:53/---
Alternatively, you can view the mroute table for specific component.
SEFOS# show ip pim mroute 1 summary
Or, you can also view the mroute table for a specific group.
SEFOS# show ip pim mroute 224.1.0.0 summary IP Multicast Routing Table -------------------------- Route Flags S: SPT Bit W: Wild Card Bit R: RPT Bit Timers: Uptime/Expires PIM Multicast Routing Table For Component 1 (*, 224.1.0.0) ,00:11:44/--- ,RP : 10.1.0.1 ,Route Flags : WR
