Exit Print View
These sections describe how to configure SEFOS PIM and provide examples for using various PIM commands. For additional information about these commands and options, refer to the Sun Ethernet Fabric Operating System CLI Enterprise Reference Manual.
Sample Topology
Default Settings
SEFOS1 Configuration
SEFOS2 Configuration
Enable PIM
Reducing Data Transmission Time Using the SPT
Monitor the Data Transfer Rate After a Register Stop Message
Configuring PMBR Status
Enabling Static RP Configurations
Associate an Interface to a PIM Component
Delete a PIM Interface
Configuring Designated Routers
Configuring the PIM Override Interval
Configuring PIM LAN Delay
Configuring LAN Prune Delay
Configuring BSR Candidates
Configuring PIM Query Intervals
Configuring PIM Join and Prune Messaging
Managing PIM Components
Configuring PIM Component Data Routing Modes
Configuring RP-Candidate Behavior
Configuring RP Candidate Hold Time
Configuring Static RPs
Display RP Details
Enable PIM Neighbor Recognition
Display PIM Multicast Information
