You can specify the number of packets (in bps) that must be transmitted from the group or source to cause data to be transmitted through the SPT. The SPT threshold must be configured to switch to SPT.
SEFOS# configure terminal SEFOS(config)# set ip pim enable SEFOS(config)# set ip pim threshold spt-grp 10 SEFOS(config)# set ip pim threshold spt-src 15 SEFOS(config)# end
This example transmits data through the SPT when the data transfer rate for the group exceeds 10 bps. Data is transmitted through the SPT when the data transfer rate for the source exceeds 15 bps.
SEFOS# show ip pim thresholds PIM SPT Threshold Information ----------------------------- Group Threshold : 10 Source Threshold : 15 Switching Period : 0 PIM SPT-RP Threshold Information -------------------------------- Register Threshold : 0 RP Switching Period : 0 Register Stop rate limit : 5
