You can specify the amount of time (in seconds) the RP monitors registered packets for switching to the source-specific SPT. The RP switching period must be configured to switch to SPT.
SEFOS# configure terminal SEFOS(config)# set ip pim enable SEFOS(config)# set ip pim rp-threshold 10 SEFOS(config)# set ip pim rp-switchperiod 15 SEFOS(config)# end
This example switches the RP to the source-specific SPT after 10 registered packets are received and monitors the activity for 15 seconds.
SEFOS# show ip pim thresholds PIM SPT Threshold Information ----------------------------- Group Threshold : 10 Source Threshold : 15 Switching Period : 5 PIM SPT-RP Threshold Information -------------------------------- Register Threshold : 10 RP Switching Period : 15 Register Stop rate limit : 5
