Enabling a static RP for a multicast group can be a fairly simple way to define RPs in configurations that have few RPs, but should generally be avoided in complex environments with numerous RPs. If you enable a static RP, its settings will take precedence over other RPs.
Specify whether to use the configured static-RP by either enabling or disabling static-rp.
