Default Settings
The following table contains the default settings that are
configured for PIM in a SEFOS switch. If the switch is rebooted
for any reason, it returns to the previously saved configuration.
If you have not saved a site configuration, the reboot returns the switch
to the default settings. For instructions on how to save your site
configuration, refer to the software configuration guide for your
switch.
PIM module status |
Enabled |
PIM SPT group threshold |
0 |
PIM SPT source threshold |
0 |
PIM SPT-switch period |
0 seconds |
PIM RP-threshold |
0 |
PIM RP-switch period |
0 second |
PIM regstop-ratelimit-period |
5 seconds |
PIM PMBR status |
disable |
PIM static-RP |
disable |
PIM component mode |
sparse |
RP-candidate holdtime |
0 second |
PIM query-interval |
30 seconds |
PIM message-interval |
60 seconds |
PIM bsr-candidate |
0 |
PIM component ID |
1 |
PIM hello-hold time |
105 seconds |
PIM DR-priority |
1 |
PIM override-interval |
0 second |
PIM lan-delay |
0 second |
PIM lan-prune-delay |
disable |
