A PMBR integrates two different PIM domains (either PIM-SM or PIM-DM) to connect a PIM domain to other multicast-routing domains. You can enable or disable the reporting of PMBR status for a given domain. By enabling PMBR status reporting on a specific router, that router behaves as a PMBR router.
