Go to main content
Sun Datacenter InfiniBand Switch 36 Documentation Supplement for Firmware Version 2.2
Exit Print View
Updated: September 2016
switch Object Commands
Description
Syntax
Add a switch to the fabric configuration file.
add switch name=hostname ip=mgmt_eth_ip rack=rack_name fabric=fabric_name sm=enabled|disabled
Remove a switch from the fabric configuration file.
remove switch name=hostname|ip=mgmt_eth_ip
where:
  • hostname is the host name of the management controller.
  • mgmt_eth_ip is the IP address of the management controller.
  • rack_name is the identifier of the rack.
  • fabric_name is the identifier of the fabric.
Related Information
