Go to main content
Sun Datacenter InfiniBand Switch 36 Documentation Supplement for Firmware Version 2.2
Exit Print View
Updated: September 2016
Enable or Disable a Subnet Manager (Toolbox CLI)
  • In the Toolbox CLI, enable or disable the Subnet Manager.
    [toolbox-cli] set sm name=name|ip=IP_address action=state
    where:
    • name is the host name of the switch hosting the Subnet Manager.
    • IP_address is the IP address of the management controller of the switch.
    • state is either enabled or disabled.
    For example, to enable the Subnet Manager on a host with host name nsn156-102, type:
    [toolbox-cli] set sm name=nsn156-102 action=enable
    Are you sure you want to enable SM on 10.134.156.102? (y/n): y
    Performing enable SM on 10.134.156.102...  [OK]
    Sleeping for 10 seconds to let SM state change happen...  [OK]
    Verifying SM states in fabric...  [OK]
    Acquiring Global Lock... [OK]
    Protecting Fabric(s) based on MKey(s) provided ... [OK]
    Determining Master SM node... [OK] : "nsn156-81"
    Gathering fabric data... [OK]
    Releasing Global Lock... [OK]
    Updating fabric conf file: /etc/toolbox/conf/fabric.conf...  [OK]
    [toolbox-cli]
Related Information
