Go to main content
Sun Datacenter InfiniBand Switch 36 Documentation Supplement for Firmware Version 2.2
Exit Print View
Updated: September 2016
Remove a Partition (Toolbox CLI)
  1. In the Toolbox CLI, remove the partition.
    [toolbox-cli] remove partition name=name|pkey=P_Key
    where:
    • name is the partition name.
    • P_Key is the partition key.
    For example, to remove the partition with P_Key 1122, type:
    [toolbox-cli] remove partition pkey=1122
    Are you sure you want to remove partition 'pkey="1122"'? (y/n): y
    [toolbox-cli]
  2. Verify that the partition was removed.
    [toolbox-cli] show partition name=all
    NAME         PKEY     FLAGS
    SUN_DCS      0001     ipoib
    nm2-box1     3342     ipoib, defmember=full
    nm2-box2     3343
    nm2-box      3341
    nm2-box3     3344     ipoib, defmember=both
    Default      7fff     ipoib
    nm2-box4     3345     ipoib, defmember=full
    [toolbox-cli]
Related Information
