The backup operation copies the backup file to every switch in the Toolbox CLI fabric configuration file.
[toolbox-cli] set config backup switch=name|all
where name is the host name of the switch hosting the Subnet Manager. For example, to back up the switch with host name nsn178-158, type:
[toolbox-cli] set config backup switch=nsn178-158 passphrase: passphrase The backup will use passphrase 'p******'. Do you want to continue? (y/n): y ilom-admin password: password Copying ilom backup from nsn178-158 to nsn178-159... [OK] Copying ilom backup from nsn178-158 to nsn178-157... [OK] [toolbox-cli]
For example, to back up all switches in the toolbox fabric configuration file, type:
[toolbox-cli] set config backup all passphrase: passphrase The backup will use passphrase 'w***************'. Do you want to continue? (y/n): y ilom-admin password: password Copying ilom backup from nsn178-158 to nsn178-159... [OK] Copying ilom backup from nsn178-158 to nsn178-157... [OK] Copying ilom backup from nsn178-159 to nsn178-158... [OK] Copying ilom backup from nsn178-159 to nsn178-157... [OK] Copying ilom backup from nsn178-157 to nsn178-158... [OK] Copying ilom backup from nsn178-157 to nsn178-159... [OK] [toolbox-cli]
