The toolbox daemon monitors actions in the fabric management, and performs activities as a Subnet Manager agent. The toolbox daemon has secret M_Key privileges.
[toolbox-cli] set daemon state
where state is either enable or disable.
For example, to enable the toolbox daemon, type:
[toolbox-cli] set daemon enable Are you sure you want to enable the Toolbox Daemon? (y/n): y
fabric conf file(s) '/etc/toolbox/conf/fabric.conf' not found. Create file? (y/n) [y]:
If the fabric configuration file is missing, create it.
Initializing... Setting up passwordless SSH... Parsed following
configuration:
1 fabric(s) specified in config.
Config Summary : ----------------
* Fabric 'TEST' (MKey: 0x3815345c5d4b4880) has 2 rack(s):
> Rack 'o4nm2' has 1 switch(es):
- o4nm2-gw-8 (10.172.144.13) , SM expected: 'enabled'
> Rack 'generic' has 1 switch(es):
- test324 (10.172.144.147) , SM expected: 'enabled'
Do all these switches share the same 'ilom-admin' password? (y/n) [y]: Switch 'ilom-admin' Password?: password Confirm Password: password
The initialization continues.
No existing RSA keys found for toolbox Enable toolbox user if not done so ..[OK] Generating RSA key pair for toolbox ....[OK] Setting up passwordless access for toolbox at 10.172.144.13 ........[OK] Setting up passwordless access for toolbox at 10.172.144.147 ........[OK] [OK] Setting up sessions... [OK] Verifying Switch FW versions in fabric... [OK] Verifying SM states in fabric... [OK] Acquiring Global Lock... [OK] Single Master SM found: 10.172.144.13 Protecting Fabric(s) based on config provided ... [OK] Determining Master SM node... [OK] : "o4nm2-gw-8" Gathering fabric data... [OK] Generating API Key... [OK] Releasing Global Lock... [OK] Starting daemon... [OK] [toolbox-cli]
