[toolbox-cli] set settings GUID_REPLACEMENT=1 Done. Restart daemon for changes to take effect. [toolbox-cli]
[toolbox-cli] set settings PORT_DISABLED_ALERTS=1 Done. Restart daemon for changes to take effect. [toolbox-cli]
[toolbox-cli] set settings HCA_REPLACEMENT_ALERTS=1 Done. Restart daemon for changes to take effect. [toolbox-cli]
[toolbox-cli] set settings EMAIL_ALERTS=1 Done. Restart daemon for changes to take effect. [toolbox-cli]
Follow the instructions for your HCA.
Upon powering on the new HCA, entries are written to the log. For example:
... [15/Sep/2015 20:03:41] "INFO Node Description change detected on active HCA: scao04adm02 mlx4_0 -> scao04adm02 S 0.0.0.0,0.0.0.0 HCA-1" [15/Sep/2015 20:03:41] "INFO Node Description change detected on active HCA: scao04adm02 mlx4_0 -> scao04adm02 S 0.0.0.0,0.0.0.0 HCA-1" [15/Sep/2015 20:03:41] "INFO Toolbox alert!" [15/Sep/2015 20:03:43] "INFO Alert: New GUID in Port Switch Date: 15/Sep/2015 20:03:41 Switch: scao04sw-ibb0 Port: 10 First seen: 15/Sep/2015 20:00:12 Discovered: 15/Sep/2015 20:00:12 Last seen: 15/Sep/2015 20:03:40 New caguid: 0x000000001234abcd New port guid: 0x000000001234abcf Type: HCA Description: scao04adm02 S 0.0.0.0,0.0.0.0 HCA-1 Old caguid: 0x0002c90300a3ca60 Old port guid: 0x0002c90300a3ca62 New GUID in Port Switch Date: 15/Sep/2015 20:03:41 Switch: scao04sw-iba0 Port: 10 First seen: 15/Sep/2015 20:00:12 Discovered: 15/Sep/2015 20:00:12 Last seen: 15/Sep/2015 20:03:39 New caguid: 0x000000001234abcd New port guid: 0x000000001234abce Type: HCA Description: scao04adm02 S 0.0.0.0,0.0.0.0 HCA-1 Old caguid: 0x0002c90300a3ca60 Old port guid: 0x0002c90300a3ca61
If configured, an email is sent. For example:
Send Mail ['root@localhost.com']: Done" [15/Sep/2015 20:03:46] "INFO Replacing GUID 0x0002c90300a3ca61 --> 0x000000001234abce" [15/Sep/2015 20:03:49] "INFO Replacing GUID 0x0002c90300a3ca62 --> 0x000000001234abcf" ...
