[toolbox-cli] set partition name=name|pkey=P_Key remove port portguid=GUID
where:
name is the partition name.
P_Key is the partition key.
GUID is the port GUID.
For example, to remove the port with GUID 0x0002c90300089240 from the partition with P_Key 1122, type:
[toolbox-cli] set partition pkey=1122 remove port portguid=0x0002c90300089240 Are you sure you want to remove partition port 'portguid="0x0002c90300089240"'? (y/n): y [toolbox-cli]
There is also a "no confirm" mode where you can specify a -y flag when removing a partition to disable the confirmation prompt.
[toolbox-cli] show partition pkey=1122 ports NAME : test4 PKEY : 1122 FLAGS : ipoib, rate=4, sl=5 GUID MEMBER ------------------ ------- 0x0002c903000891ac full [toolbox-cli]
