[toolbox-cli] remove switch ip=IP_address|name=switch_name
where:
IP_address is the IP address of the management controller of the switch.
switch_name is the host name of the switch.
For example, to remove the switch with host name scao04sw-iba0 from the fabric configuration, type:
[toolbox-cli] remove switch name=scao04sw-iba0 Are you sure you want to remove switch 'name="scao04sw-iba0"'? (y/n): y Updating fabric conf file: /etc/toolbox/conf/fabric.conf... [OK]
