Go to main content
Sun Datacenter InfiniBand Switch 36 Documentation Supplement for Firmware Version 2.2
Exit Print View
Updated: September 2016
Configure a Subnet Manager (Toolbox CLI)
  1. In the Toolbox CLI, disable the Subnet Manager to be configured.
    See Enable or Disable a Subnet Manager (Toolbox CLI).
  2. Configure the Subnet Manager.
    [toolbox-cli] set sm name=name|ip=IP_address -priority=priority|-controlledhandover={TRUE|FALSE}|-prefix=prefix|-mkey=M_Key
    where:
    • name is the host name of the switch hosting the Subnet Manager.
    • IP_address is the IP addres of the management controller of the switch.
    • priority is the Subnet Manager priority.
    • prefix is the Subnet Manager prefix.
    • M_Key is the management key.
    For example, to set the priority to 3, disable controlled handover, and set the management key to 0xa00000000001 for the Subnet Manager with name nsn156-102, type:
    [toolbox-cli] set sm name=nsn156-102 -priority=3 -controlledhandover=FALSE -mkey=0xa00000000001
    [toolbox-cli]
  3. Verify the configuration changes.
    [toolbox-cli] show sm all
    nsn156-102  (10.134.156.102)
    SM:                           STAND BY
    STATE:                        disabled
    PRIORITY:                     3
    CONTROLLED_HANDOVER:          FALSE
    SUBNET_PREFIX:                0xfe80000000000000
    MKEY:                         0xa00000000001
    ROUTING_ENGINE:               FatTree
    nsn156-81  (10.134.156.81)
    SM:                           MASTER
    STATE:                        enabled
    PRIORITY:                     0
    CONTROLLED_HANDOVER:          TRUE
    MKEY:                         None
    [toolbox-cli]
  4. Enable the Subnet Manager.
Related Information
