man pages section 3: Extended Library Functions, Volume 1
Exit Print View
Updated: July 2014
cpc_getcpuver(3CPC)
Name
cpc_getcpuver, cpc_getcciname, cpc_getcpuref, cpc_getusage, cpc_getnpic, cpc_walk_names - determine CPU performance counter configuration
Synopsis
cc [ flag... ] file... −lcpc [ library... ]
#include <libcpc.h>
int cpc_getcpuver(void);
const char *cpc_getcciname(int cpuver);
const char *cpc_getcpuref(int cpuver);
const char *cpc_getusage(int cpuver);
uint_t cpc_getnpic(int cpuver);
void cpc_walk_names(int cpuver, int regno, void *arg,
     void (*action)(void *arg, int regno,  const char *name,
     uint8_t bits));
Description
The cpc_getcpuver() function returns an abstract integer that corresponds to the distinguished version of the underlying processor. The library distinguishes between processors solely on the basis of their support for performance counters, so the version returned should not be interpreted in any other way. The set of values returned by the library is unique across all processor implementations.
The cpc_getcpuver() function returns −1 if the library cannot support CPU performance counters on the current architecture. This may be because the processor has no such counter hardware, or because the library is unable to recognize it. Either way, such a return value indicates that the configuration functions described on this manual page cannot be used.
The cpc_getcciname() function returns a printable description of the processor performance counter interfaces-for example, the string UltraSPARC I&II. Note that this name should not be assumed to be the same as the name the manufacturer might otherwise ascribe to the processor. It simply names the performance counter interfaces as understood by the library, and thus names the set of performance counter events that can be described by that interface. If the cpuver argument is unrecognized, the function returns NULL.
The cpc_getcpuref() function returns a string that describes a reference work that should be consulted to (allow a human to) understand the semantics of the performance counter events that are known to the library. If the cpuver argument is unrecognized, the function returns NULL. The string returned might be substantially longer than 80 characters. Callers printing to a terminal might want to insert line breaks as appropriate.
The cpc_getusage() function returns a compact description of the getsubopt()-oriented syntax that is consumed by cpc_strtoevent(3CPC). It is returned as a space-separated set of tokens to allow the caller to wrap lines at convenient boundaries. If the cpuver argument is unrecognized, the function returns NULL.
The cpc_getnpic() function returns the number of valid fields in the ce_pic[] array of a cpc_event_t data structure.
The library maintains a list of events that it believes the processor capable of measuring, along with the bit patterns that must be set in the corresponding control register, and which counter the result will appear in. The cpc_walk_names() function calls the action ( ) function on each element of the list so that an application can print appropriate help on the set of events known to the library. The arg parameter is passed uninterpreted from the caller on each invocation of the action( ) function.
If the parameters specify an invalid or unknown CPU or register number, the function silently returns without invoking the action function.
Usage
Prior to calling any of these functions, applications should call cpc_access(3CPC) to determine if the counters are accessible on the system.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
MT-Safe
Interface Stability
Obsolete
See also
cpc(3CPC), cpc_access(3CPC), cpc_cciname(3CPC), cpc_cpuref(3CPC), cpc_npic(3CPC), cpc_walk_events_all(3CPC)libcpc(3LIB), attributes(5)
Notes
The cpc_getcpuver(), cpc_getcciname(), cpc_getcpuref(), cpc_getusage(), cpc_getnpic(), and cpc_walk_names() functions exist for binary compatibility only. Source containing these functions will not compile. These functions are obsolete and might be removed in a future release. Applications should use cpc_cciname(3CPC), cpc_cpuref(3CPC), cpc_npic(3CPC), and cpc_npic(3CPC) instead.
Only SPARC processors are described by the SPARC version of the library, and only x86 processors are described by the x86 version of the library.
