man pages section 3: Extended Library Functions, Volume 1
Exit Print View
Updated: July 2014
dat_evd_clear_unwaitable(3DAT)
Name
dat_evd_clear_unwaitable - transition the Event Dispatcher into a waitable state
Synopsis
cc [ flag… ] file–ldat [ library… ]
#include <dat/udat.h>
DAT_RETURN
    IN    DAT_EVD_HANDLE    evd_handle
Parameters
evd_handle
Handle for an instance of Event Dispatcher.
Description
The dat_evd_clear_unwaitable() transitions the Event Dispatcher into a waitable state. In this state, calls to dat_evd_wait(3DAT) are permitted on the EVD. The actual state of the Event Dispatcher is accessible through dat_evd_query(3DAT) and is DAT_EVD_WAITABLE after the return of this operation.
This call does not affect a CNO associated with this EVD at all. Events arriving on the EVD after it is set waitable still trigger the CNO (if appropriate), and can be retrieved with dat_evd_dequeue(3DAT).
Return Values
DAT_SUCCESS
The operation was successful.
DAT_INVALID_HANDLE
The evd_handle parameter is invalid.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Safe
Standard
uDAPL, 1.1, 1.2
See Also
dat_evd_dequeue(3DAT), dat_evd_query(3DAT), dat_evd_set_unwaitable(3DAT), dat_evd_wait(3DAT), libdat(3LIB), attributes(5)
