man pages section 3: Extended Library Functions, Volume 1
Exit Print View
Updated: July 2014
di_prop_devt(3DEVINFO)
Name
di_prop_bytes, di_prop_devt, di_prop_ints, di_prop_name, di_prop_strings, di_prop_type, di_prop_int64 - access property values and attributes
Synopsis
cc [ flag... ] file... –ldevinfo [ library... ]
#include <libdevinfo.h>
int di_prop_bytes(di_prop_t prop, uchar_t **prop_data);
dev_t di_prop_devt(di_prop_t prop);
int di_prop_ints(di_prop_t prop, int **prop_data);
int di_prop_int64(di_prop_t prop, int64_t **prop_data);
char *di_prop_name(di_prop_t prop);
int di_prop_strings(di_prop_t prop, char **prop_data);
int di_prop_type(di_prop_t prop);
Parameters
prop
Handle to a property returned by di_prop_next(3DEVINFO).
prop_data
For di_prop_bytes(), the address of a pointer to an unsigned character.
For di_prop_ints(), the address of a pointer to an integer.
For di_prop_int64(), the address of a pointer to a 64–bit integer.
For di_prop_strings(), the address of pointer to a character.
Description
These functions access information associated with property values and attributes. All memory allocated by these functions is managed by the library and must not be freed by the caller.
The di_prop_bytes() function returns the property data as a series of unsigned characters.
The di_prop_devt() function returns the dev_t with which this property is associated. If the value is DDI_DEV_T_NONE, the property is not associated with any specific minor node.
The di_prop_ints() function returns the property data as a series of integers.
The di_prop_int64() function returns the property data as a series of 64–bit integers.
The di_prop_name() function returns the name of the property.
The di_prop_strings() function returns the property data as a concatenation of null-terminated strings.
The di_prop_type() function returns the type of the property. The type determines the appropriate interface to access property values. The following is a list of possible types:
DI_PROP_TYPE_BOOLEAN
There is no interface to call since there is no property data associated with boolean properties. The existence of the property defines a TRUE value.
DI_PROP_TYPE_INT
Use di_prop_ints() to access property data.
DI_PROP_TYPE_INT64
Use di_prop_int64() to access property data.
DI_PROP_TYPE_STRING
Use di_prop_strings() to access property data.
DI_PROP_TYPE_BYTE
Use di_prop_bytes() to access property data.
DI_PROP_TYPE_UNKNOWN
Use di_prop_bytes() to access property data. Since the type of property is unknown, the caller is responsible for interpreting the contents of the data.
DI_PROP_TYPE_UNDEF_IT
The property has been undefined by the driver. No property data is available.
Return Values
Upon successful completion, di_prop_bytes(), di_prop_ints(), di_prop_int64(), and di_prop_strings() return a non-negative value, indicating the number of entries in the property value buffer. See di_prom_prop_lookup_bytes(3DEVINFO) for a description of the return values. Otherwise, -1 is returned and errno is set to indicate the error.
The di_prop_devt() function returns the dev_t value associated with the property.
The di_prop_name() function returns a pointer to a string containing the name of the property.
The di_prop_type() function can return one of types described in the DESCRIPTION section.
Errors
These functions will fail if:
EINVAL
Invalid argument. For example, the property type does not match the interface.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Safe
See Also
di_prom_prop_lookup_bytes(3DEVINFO), di_prop_next(3DEVINFO), libdevinfo(3LIB), attributes( 5)
Writing Device Drivers for Oracle Solaris 11.2
